Sound from the speakers
K
khiyal
I have checked and rechecked all my cabling, Ran the auto setup, and even tried a bit tweaking using the manual setup. No errors reported for size or cabling. Regardless, I hear no sound from my speakers until the sound level is at -50 db or higher. For the first 80-50 db it is a very faint volume. I recently had my ear exam so that should not be an issue :)
I have a Yamaha RX-v2400 receiver connected to 5.1 JBL SCS160 SI speakers and SCS160 sub. Any help will be appreciated.
AVRat
AVRat
Your not going to hear decent sound until you are above about -40 dB. -20 should be very good:), -10 if you get there:D, 0 db :eek:
Every 1 dB change in/decreases power by about 26%. This is an exponential change. So let's work backwards, say 100W @ 0 dB.
-10 dB = 10W
-20 dB = 1W
-30 dB = 0.1W
K
khiyal
hmm, OK. However, I used to have pretty decent volume at around -55, -50 db. It is after I moved and redid my setup that I started noticing this. I guess it may be the shape/size of the room and amount of furniture that may have contributed to this, then.
If you look at the display, it shows -50dB, etc and that means it has been attenuated that much from the reference level. 55dB is a long way from that reference level and if you want to reproduce the signal cleanly at -0dB when the amp is putting out 1W at -20dB, it has to be able to put out 100W at -0dB.
AVRat
AVRat
Yes, size does make a difference. Especially if it's drastically larger, volume wise.
