One of the best sounds card on the budget is Asus Xonar DS
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132013&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Sound+Card-_-ASUS-_-29132013
40 AR + 2 S&H = you can't go wrong...
There are of course better cards out there, but you can't buy better card for $40
thanks for the reply - i will check it out
What speakers/sub are you looking to get? Whats the budget?
i try to be as cheap as possible, the prices to buy in Canada are usually higher than paying to ship/duty/brokerage fees from american companies. very few companies ship to Canada though
some ideas i have so far, feel free to critique my ideas.
Wharfedale Package (don't need all the pieces but i like the price)
4 Bookshelf Speakers - 2 Diamond 9.0 + 2 9.SR
1 Centre Channel - Diamond 9.cc
1 Subwoofer - SW150 - 10" Powered Sub
534.96 Shipped to Canada
Jamo
Jamo C 403 (Dark Apple) - 149.88
Jamo SUB250BA - 129.88
Premiere Acoustic
Premier Acoustic PA-4.0 Monitors - 104.00
Premier Acoustic PA-120 Subwoofer - 229.00
if i open up the budget a bit
Axiom
EP125 8" Subwoofer - 375.00
M3 V2 Bookshelf Speakers - 330.00
couple receivers i am looking at
Yamaha RX-V363 (Usaworldsales.com - not sure if reputable outlet) - 139.00
used Yamaha HTR-6060 - 229.00
