Sound Card questions....
Y
Yamaheart
Hi all, my sound card is Creative SB X-Fi Audio. What I am doing is direct the sound from this card to my Mixer(Behringer XenyX2442FX) and from the Mixer back to the input of this card for recording. Im using Nero WaveEditor for recording. The record file sound okay but the volume is way to low. I had to crank up my speaker volume to max to get a good sound. The question is can you multi-task this card, meaning playing and recording at the same time? Is there something that I have to do from my mixer to send the signal higher? Thanks all...
Shock
Shock
Can you not just select "What you hear" for recording your output? Or are you applying some processing to the audio in your mixer?
Y
Yamaheart
Yeah, recording a Live concert at home here, hehehe..
