Hi everyone,
I am new to these forums. I just wanted somewhere to discuss (or rant in this case) about AV things, and this place seems friendly and has lots of knowledgeable people.
I have had lots of low-to-mid-range projectors over the past 7 years. It was just a bad period for keeping the same projector with all the resolution advances.
I have always set the projector on a shelf behind my seats with the lens at the horizontal center and top of my Carada Brilliant White screen. First the Sharp DT-200 DLP served me well but I needed an upgrade just because the resolution was weak (it died for the person I sold it to at about 700 hours into the second lamp). Then I got an Optima H77 DLP, which turned out to be the most worthless piece of junk in history, and with terrible customer service to boot (3 warranty returns, one of them after only 5 hours on the bulb, resulted in a refurbished model with who-knows how many hours on the bulb). My last one was a Sony 3LCD 720p VPL-HS51 (or HS50, can't recall). This one was good, but it was 720p. I have about 2600 hours on this one and it has served well, but this is the era of 1080p (I am sure the era of 2k, 4k, 8k, etc. aren't far off).
So besides some annoying aspect ratio lockout on the VPL-HS51, it served me well, and thus (after reading many reviews) I purchased a Sony VPL-VW40. To my surprise, it has hardly any lens shift. Nowhere in product specifications (or the reviews that I read, or the dealer I bought it from) does it say that it only has a 67% positive vertical lens shift (no negative shift at all). Since my shelf is built into the wall there is nothing to do but return it. Rar. Enter Epson Home Cinema 1080 UB I guess.
I know it is discontinued but I just wanted to whine and hopefully help at least one person in my situation avoid similar disappointment when shopping for a bargain on a 2008 model projector.
