A Word of Caution
papostol said:
Hi all,
Has anyone installed a Sony VPL HS51 front projector? I currently in the market for one and wanted any insight from someone who knows about this projector.
I plan on using a 110" Dalite.
Thanks! Peter
You are proposing a huge screen. Do you know the distance from the screen you need to hang it??? For that size, your room may not be long enough.
I am investigating these issues, reading different web sites such as Runco, etc.
Light output on the screen is not an easy proposition to determine.
http://www.axiomaudio.com/distortion.html#
Before you buy any front projector, research this, how much actual light in foot Lambert (Lumens per sq. ft) will be on your screen at the size you intend to use and the projector's video calibrated to a known standard, at 6500K.
No, the published Lumen is not even close nor gives you an idea. In my research, this figure is what a projector will output at full blast, uncalibrated and usually around 9000K - 16000K temps. At 6500K Runco only gets 48% of the lumen number they advertised as ANSI Lumens. Other projectors may differ on that percentage.
Theaters using film has a goal of 16 ft-Lambert with no film and open gate.
Runco has some such specs published at their web site for their projectors but you have to look carefully. They publish 3 different light levels: ANSI lumens, CSMS lumens and ft-Lambert.
Magazine reviews such as Sound & Video publishes the display light out or reflection on a screen as yours(not its size) in foot Lamberts. But, this depends on your screen size. Runco uses a 72" wide screen. Its area is almost 1/2 the size of yours so your screen would get 1/2 the foot-lambert. So, if their projector is rated at 18FL you would get only about 9 FL.
When you calculate the square footage of the Runco screen size(72"x40") and multiply that by the Foot Lambert rating of their projector, it doesn't equal their 6500K calibrated light output they call CSMS Lumens. It is less.
The bigger your screen, the more your planned projector needs to output. I am still researching and have yet to read that link above. It may have the answers, not sure.
Make a long story short, there is more to this than meets the eye and may be in for a dark picture and a disappointment. Sorry for the bad news.
