aqilea
Hi Every One
I Just Bought Sony Ta-e9000es From The Goowill With A Good Price , When I Got Home I Found Out That It Needs The Ta-n9000es To Go With In Order For It To Work . I Have No Idea If Any Others Amplifiers Will Be Able To Work With It And If There Is Any Way To Test The Unit Without Having The Amplifier. And Any One Has The Upgraded Software For Download .
Any Help Will Be Appricated.
Seth=L
Seth=L
Good news for you, you don't need to get the N9000ES for it to work. You just need an amplifier. You see, if you go to a Best Buy or some such store they sell lower end solutions for surround sound in the form of what is known as a receiver. A receiver is made of two essential parts, a preamp/processor and an amplifier. The Sony TA-E9000ES is a preamp/processor, it decodes a signal, controls audio levels and other parameters as well as switching between various components such as CD players, Tape decks, DVD players and other gear.
An amplifier does just what the name implies, it amplifies a signal for output to speakers. It takes low level, but variable (volume controlable), output from a preamp/processor and increase the power to be fed to hungry speakers.:D
Now, the reason you don't need the Sony TA-N9000ES amplifier, preamp/processors are all pretty standard concerning output, so you can connect it to a large variety of different amplifiers ranging outside the Sony brand if you should chose (this is likely the best choice to look outside the Sony brand for amplification anyway).
There are a plethra of brands of amplifiers out there to look at, the best suggestion I can make is to set a budget and we will continue to help you in your venture to pursue audio nirvana.:D You have stumbled on one of the best pieces of Sony's audio legacy, and they are few and far between.;) Did this one by any chance come with a remote, and if you don't mind my asking, how much did you get it for?:D
Test it via headphones on the front of the unit with a source connected, such as a DVD player or CD player.:)
Good luck, and we look forward to hearing from you. Send me a PM when you return.
Seth=L
Adam
Adam
You can also find some information at the Sony support site. Click here for your model. Among other things there is the owner's manual.
aqilea
THANK YOU ALL FOR THE REPLAY.
I bought it for only 10$ has no remote ,I took the risk for it .now i hook it up to the dvd,TV,SAT. but no sound or picture .after serching the found the software to download 1.10c ver ,download it and still no picture or sound.for now i will hold on it ,and if any one has the idea what is wrong,I found the service manual with all the schamatic and p/n,s but does not tells you were to start or the troobleshooting.
again thank you all and I will post any fix I will find.
ryan110
I own both the TA-E9000ES pre-amplifier and the TA-N9000ES power amplifier, which I purchased off of ebay. First thing I have to say is that I love them.
To answer a few questions .....
The most recent firmware update that there is for the TA-E9000ES is V 2.01c
keeping in mind that there is a V 2.50, but that was only used in Japan because the firmware update added decoding of MPEG-AAC audio which was used by digital satellite broadcasting. Thus its not important to you (unless your from Japan).
The only issue that I have with the TA-E9000ES is the remote it comes with. It originally came with a giant touch screen remote that absolutely eats batteries. I know that the VUCD-E9000A upgrade kit was made available some time in the late 1990's, and that came with a smaller yet less practical remote.
My advice to you would be to acquire the upgrade kit which I will show you how to do in a link I will post below.
The upgrade kit downloads to the pre-amp via RS232c connection fyi.
Here are a few links that are dedicated to these units that have helped me over the years.
http://home.online.no/~espen-b/ta-e9000es/#user[/url]
http://members.iinet.net.au/~rutlidge/TA-E9000ES_1.html[/url]
Hope I could help,
Good Luck
