Product Specifications
Supplied accessories : Remote Control; Instruction Manual; AC Power Cord
Audio Inputs : 1 Balanced; 4 Unbalanced
Headphone Out : Low (8 Ω) 500 mW + 500 mW Mid (150 Ω) 500 mW + 500 mW Hi (300 Ω) 250 mW + 250 mW
(8Ohms 20-20kHz) THD : 0.09%
8Ohms 20-20kHz : 80W+80W
8Ohms 1kHz : 80W+80W
4Ohms 20-20kHz : 80W+80W
Power Requirements : 120V 60Hz
Power Consumption : 300W
Auto Standby : Yes
Number of Amp channels : 2ch
Speaker Impedance : 4ohm
Power Consumption (Stand By) : 0.4W
Frequency Characteristics : 20Hz-100KHz
Detachable AC : Yes
4 Ohm/8 Ohm Switching : Yes
OP Processing : Yes
Signal-to-Noise Ratio(A Network) (When all of EQ/Surround off) : 96dB
Speaker Out : Yes (Front A - L/R)
Speaker Terminal : Screw
Total Harmonic Distortion : 0.008% 1KHz 10W 8ohm
IR Repeat (In/Out) : Yes (in)
Weights and Measurements
Dimensions (Approx.) : Receiver: 17 x 5 1/8 x 16 5/8 in (430mm x 130mm x 420 mm)
Weight (Approx.) : Receiver: 39 lbs 11 oz (18.0 kg) Gross: 41 lbs 14 oz (19 kg)
Interesting for the 2 chl folks
