das105
Hi,
Will the Sony Str-DN1080 be enough to power the following?
2 x Klipsch Reference R-28F
Klipsch Reference R-25C
2 x Klipsch Reference R-15M
Klipsch Reference R-12SW Powered Subwoofer
Does the powered subwoofer change how I connect to the receiver?
Thanks.
The avr will be fine with the speakers. You simply use the sub pre-out on the receiver to connect to the active sub...otherwise not sure what you mean by "change how I connect to the receiver"?
