I am not particular on either of these ..I just happen to have both...I really want to get a seperat amp and tuner but right now I have these...I only need one of them
I havent spent much time with the Sony. I know its about the same rated in watts but havnt played them on my big speakers
I am thinking I should just sell off the SOny cheap and keep the HK for now..although I like the older HK better..all I need is a 2 channel for music
You said "older" HK. I looked up that model of the Sony and it seems pretty old and I looked up the HK and it seems pretty new.
Does your HK look like this?
If that's the HK you have I'd suggest keeping it. It has preamp outputs so you can use it it as a preamp if you want. I don't believe the Sony has this feature. I also imagine the resell value of the HK would be higher than the Sony because it is a superior receiver.
Again, this is all assuming that the HK looks like the one above. If not, please make sure the model is exactly correct and or take a picture.
