320.00$
only 2 months old still have box and instructions. Will pay shipping anywhere in the lower 48 states. Pics available upon request.
thanks
Fully Customizable (Screen, Layout, Key Label, IR Code, Macros)
Data Exchange through USB or Memory Stick(R) Media
3.5 Inches Color TFT Display (65,536 Color)
New Tactile Response Touch Panel
High Speed Data Down/Upload with USB Connection and Memory Stick(R) Media
Easy Unique Function (Direct Access Button, Favorite Channel Zapping, Etc)
Learning, Macro Command, Timer Function
Easy to Use Hard Buttons
Brushed Alumium Front Panel
Docking Station and AC Jack for Battery Recharging
Edit Software (CD-ROM)
Linux OS
Dragon Ball 2000MHz ARM9 CPU
Fully Customizable modes
3.5" Color TFT Display (65,536 Color)
Large touch-key LCD Screen : with dot-matrix area (blue backlit) for more customized screens and editable labels (258 customizable labels in total), component labels and their additional function labels, and each macro labels in dot-matrix area. 8-character labels; Easy to operate touch-key LCD indicates only the keys needed to operate the selected component. The Display backlight allows operation even in the dark
Controls up to 18 components: : TV, STB (Digital Satellite), STB2 (Digital Cable Box),VCR, VCR2, VCR3, DVD, DVD2, CD, AMP, MD, TAPE 1, TAPE B, CABLE, LD, HDVR (Hard Disk Video Recorder), DAT and Lighting. Components are selectable with six buttons on the Commander for the components frequently used and 12 keys on the LCD.
33 Macro control functions : allow series of up tp 32 consecutive operations, and execute them by pressing just one button. 15 System control macros : 3 hard buttons and 12 keys on LCD Screen (indicate by pressing the"MORE"button) 18 Device macros : 6 hard component buttons and 12 component keys on LCD Screen 4 speed selections for Macro executions
Clock and Timer function : Turn on/off your components automatically with Timer macro.(Up to 12 Timer macros)
Compatible with Sony and most major brands : and has updated pre-Programming codes
Learning function : for Programming remote signals you need (only INFRARED signals) Capable Programming remotes signals of non-A/V products such as air conditioners, lights etc. (Some specific Remote Control singnals may not be learned)
Programmable menu control : hard buttons for easy operation of Menu and EPG function
System on/off Macro : for Sony components (preset to the "SYSTEM CONTROL 1,3" buttons)
Non-volatile Memory Backup : function to keep your memorised setting
Glow-in-the-dark component select buttons : are easy-to-see
Centralized control of Sony AV components with this one remote commander : This commander is preset at the factory to operate Sony brand components, so yu canuse it out of the box as a control center for your Sony AV components
New shape design : fits in the hand and fits on the lap
