Less than 4 mos. old - asking $85 + shipping - if interested, email =
edwelly@gmail.com
The RM-AX4000 remote control comes with Sony's easy to setup PC software. It's the perfect remote control for today's home AV system, consolidating multiple remote controls into one. Exciting and convenient, this remote features an XPRESS Function for executing a series of commands, and enabling you to operate several AV components just by pressing a single key. The RM-AX4000 also controls up to 16 components, and with the Sync-up Key, synchronizing operational status on remote and alternate components is done with ease. Also featuring Tivo™/DVR functionality and an illuminated LCD touch screen allows you to highlight and view your choices. Being in the driver's seat of your living room sofa is made easy with the RM-AX4000 Home Theatre Remote Control from Sony.
Easy PC Set Up PC software and USB cable included.
• Illuminated LCD Touchscreen Back-lit LCD with adjustable brightness that activates automatically whenever the RM-AX4000 is operated, for easy operation in the dark.
• XPRESS function for easy macro setup and operation.
• TiVo®/DVR Functionality
• 16 Components (TV, DVD, VCR, CD, D-SAT, DVR.)
• Learning function for programming other remotes signals you need (only infared signals). Almost 500 non-Sony commands pre-set at the factory for use with non-Sony components.
• Touch Screen LCD for progmramming other remotes.
• Sync-up Key for synchronizing operational status on remote and components, giving you the ablilty to re-name LCD keys (up to 8 characters) for components, macros, learned commands, and individual controls.
• Clock and Timer Function Using a maximum of 8 timer macros, turn your components on and off automatically.
• Non-volatile memory function to keep your settings memorized.
