<font color='#000000'>You may have accidentally switched the input to the digital input that you are not using. The 945 has both coaxial and optical digital inputs for DVD. There should be a button on the receiver called "input mode". Switch to DVD, then push Input Mode repeatedly until "auto" appears in the display. If that doesn't do the trick, then select the digital input that you are actually using: Coaxial or Optical.</font>
