Well, the first thing you can do is disconnect everything from the receiver (while it's off of course) and then power it on and see what it does. If the error has gone away, that means that you must've had a short somewhere, most likely between the speaker terminals.
Another user had a similar problem with his Sony receiver. He found that after he opened it up, there were a few blown fuses. You should check for that as well.
