Sony or Samsung 42" TV
G
gack
The choices:
Sony KDF-42E2000
http://www.crutchfield.com/S-Sp7p4FhCdAi/cgi-bin/ProdView.asp?g=147350&I=158KD42E2K
or
Samsung HL-S4266W
http://www.circuitcity.com/ccd/productDetail.do?oid=144713&catOid=-12870&c=1&cm_re=main%20marquee-_-Save%20up%20to%2010%%20on%20select%20TVs-_-Samsung%2042
I am leaning more towards the Sony. I want to stay under $1500. The tv itself cannot be more than 42" wide(existing entertainment center) Also considering maybe a slim 46"? Height and depth are not an issue. Room size is 15'4 X 15'6 with viewing position approximately 10'. I don't know which one to get. I am about to flip a coin and decide. Any advice, comments, recommendations???? Thanks
Hemlock
not sure about the TV's but Crutchfield? Yikes, there has GOTTA be a cheaper place to buy that tv.
unless you're using a Sony card...
G
gack
Not purchasing either TV from the places shown. Just putting out a quick view on the 2 sets in question. I am probably gonna get one or the other next weekend, but still would like anyones opinions on these. Thanks.
Samsung makes the LCD panels used for Sony, so the panels in the similarly priced models are exactly the same. I'd personally go with Samsung for LCD, and I'd skip DLP completely (rainbow effect).
avliner
avliner
I do have a Sony 42" LCD and couldn't be happier, but I'm sure you'll be fine with either one, though.
Cheers / Avliner.
Jeff HDDVD
Sony Sony Sony
Samsung service is the worst! F- The thumbs down is for the Samsung, NOT the Sony!
