sony kdf-60xs955 cleaning
splatee
Hello,
I pulled the lamp out to verify the brand before i order a new one and noticed that the mirror/reflective panel that the bulb goes up to is hazy. It has what looks like a dust film almost like a haze on it. One spot is clean and shiny and the rest is hazy. I was wondering if this is something that can be cleaned or will it cause a problem? Right now i have close to 14,000 hrs on the original bulb and was going to clean the reflective/mirror panel (not sure if that is what is called) when i replace it with a new bulb.
Thank you
