Sony HX929 owners,quick question?
jmy2469
jmy2469
I just received my set,and I am trying to find the full pixel setting under the Screen menu. I have been looking, I only have a +1, -1, and a normal setting. What do I need to do to find the full pixel setting?
Hi Ho
Hi Ho
If I remember correctly, you want +1. I have set up a number of those sets. I just looked up the manual and it says +1 is used to display the "original image" which, to me, translates to full pixel.
jmy2469
jmy2469
I figured this out. It was my Verizon Fios box. It was only set to output 720p. I had to switch it to 1080i, and then was able to select the full pixel option
