Sony DA5800 ES 9.2ch 4K AV Receiver with Automation
  • Thread starter Thread starter Steve Pitbull Potenziano
Do you like the new Sony?
  • Total voters
    6
Audioholics Bouncer
Nov 6, 2014
145
0
18
57
Binghamton Ny Home Of McIntosh
Sony Seams to stepping up their game in to the high end. Are you interested at all/ Its looking like its minus Atmos but we shall see...
I do like the layout of the back. Much more user friendly. I have had Sony's in the past . They were always a good value for the sound they produced. I will Say its quite HEAVY.
MSRP: $ 2,099.99
Product Specifications
Limited Warranty
      • Amplifier/Receiver Amplifier Features
        • 4 Ohm/8 Ohm Switching : Yes (In Menu)
        • Analog Down Mix : Yes
        • Sub Woofer X' Over : 17 points (40-200Hz)
        • Number of Amp channels : 9ch
        • Bi-AMP : Yes
        • Speaker Impedance : 4 - 16ohm
        • Sound Optimizer : Yes
        • OP processing : Yes
        • DSP : Falcon2.0 + Falcon2.0
        • Digital Legato Linear : Yes
        • Speaker Selector : [A/B, A+B]
      • Amplifier/Receiver Amplifier Power
        • (4Ohms 1kHZ) THD : 0.7%
        • (8Ohms 1kHz) THD : 0.7%
        • (8Ohms 20-20kHz) : 0.09%
        • 8Ohms 1kHz : 140W+140W
      • Amplifier/Receiver CIS & Control Features
        • 2nd A : Speaker&Line (Variable&Variable)
        • IP Control : Yes
      • Amplifier/Receiver DCAC Features
        • Mic : Stereo
        • Band : 31
        • DCAC : D.C.A.C. EX
        • Speaker Relocation : Yes
      • Amplifier/Receiver Network Features
        • Direct Ethernet Update : Yes
        • Network Renderer : Yes
        • Mobile Application : ES Remote Base (iPhone/Android)
        • Sony Entertainment Network : Yes (up to video)
        • Network Client : Yes (Music/Photo/Video)
    • Audio Features
      • Audio Features Decoding Format
        • Dolby Digital EX/ Dolby Digital : Yes (Dolby Digital EX and Dolby Digital)
        • 96kHz/24bit : Yes
        • Dolby Prologic/II /IIx /IIz : Yes (II, Iıx and Iız)
        • Dolby Dual Mono : Yes
        • Dolby TruHD/Dolby Digital + : Yes (Dolby TruHD and Dolby Digital +)
        • DTS HD MA/ DTS HD HR : Yes/Yes
        • DTS / DTS-ES (Matrix6.1 / Discrete6.1) : Yes/Yes
        • LPCM (2CH/5.1CH/7.1CH) thru HDMI : Yes(Yes/Yes/Yes)
      • Audio Features Sound Field
        • Vocal Height Matching : Yes
        • True Concert Mapping: Concertgebouw/Musikverein : Yes (SB/FH)
        • PLII Movie : Yes
        • PLIIx Movie : Yes
        • PLII Music : Yes
        • Portable Audio Enhancer : Yes
        • PLIIx Music : Yes
        • PLIIz Height : Yes
        • Stadium : Yes (SB/FH)
        • Sports : Yes (SB/FH)
        • Sound Field Link : Yes
        • Movie Height : Yes
        • Live Concert : Yes (SB/FH)
        • Multi Stereo : Yes (SB/FH)
        • Neo:x Music : Yes
        • Neo:x Cinema : Yes
        • Neo:x Game : Yes
        • A.F.D. Auto : Yes
        • Berlin Philharmonic Hall : Yes (SB/FH)
        • HD-D.C.S. : Yes (SB/FH)
        • Analog Direct : Yes
        • Headphone 2ch : Yes
        • Headphone Direct : Yes
        • Jazz Club : Yes (SB/FH)
        • Headphone Multi : Yes
        • 2ch : Yes
      • Audio Features Tuner
        • Station Name : Yes
        • Auto Tuning : Yes
        • Preset Channel (FM/AM) : TTL60 (30/30)
        • Direct Tuning : Yes (RM)
    • General
      • General Installation
        • 2nd V : CAT5 & Composite & Component & HDMI
        • Certification (AMX/Crestron/Control 4) : Yes
        • 3rd A : Line (Fix)
        • RS-232C for Control : Yes
        • IR Repeat (In/Out) : Yes(1 in/4 out)
      • General Other
        • Power Requirement : 120V 60Hz
        • Power Consumption (Power Stand By) : 0.5W
        • Power Consumption : 500W
        • Pin Jack : Nickel
        • Sleep Timer : Yes (up to 2 hours)
        • Auto Standby : Yes
        • DCS/HD-DCS LED : HD-D.C.S, Berlin Philharmonic Hall True Concert Mapping
        • Assignable HDMI Video In : Yes
        • Attachment : IR emitter x4, Zigbee Dongle
        • Easy Automation : Yes
        • Digital Input Assign : Yes
        • Detachable AC : Yes
        • GUI Language : En/Fr/Dl/Sp
        • GUI : Yes (New Rich Grade)
        • Multi Channel Decoding Blue LED : Yes
        • Panel : Alumi/ES
        • iPod Browsing with System (via USB) : Yes (Video/Music)
        • Assignable Component Video In : Yes
        • AC Outlet (Switched) : Yes(2)
    • Inputs and Outputs
      • Inputs and Outputs Audio Inputs
        • Analog Audio In : 3
        • Coaxial : 3
        • Phono (MM) : Yes
        • Multi-ch In : Yes (FM and AM)
        • Optical In : 3
      • Inputs and Outputs Audio Outputs
        • Pre Out (Front (L/R)) : 21 5/8 x 12 3/8 x 19 3/4 in
        • Pre Out (Center) : Yes
        • Pre Out (Subwoofer) : 2
        • Pre Out (Front Height (L/R)) : Yes
        • Pre Out (Surround Back (L/R)) : Yes
        • Pre Out (Surround (L/R)) : 48lb 9oz
        • Headphone Out : Yes
        • Analog Audio Out : 1
      • Inputs and Outputs Other Inputs and
        • USB : 2 (Front:iPhone/WM + Back:for Zigbee)
        • Ethernet (Switching HUB) : 4(Yes)
      • Inputs and Outputs Speaker Outputs
        • Center : Yes
        • Front (Bass/Treble) : Yes/Yes
        • Front A (L/R) : Yes
        • Front B (L/R) : Yes
        • Front High (Bass/Treble) : Yes/Yes
        • Surround (L/R) : Yes
        • Front High (L/R) : Yes
        • Surround Back (L/R) : Yes
        • Surround Back (Bass/Treble) : Yes/Yes
        • Surround (Bass/Treble) : Yes/Yes
      • Inputs and Outputs Video Inputs
        • Component Video In : 2
        • AV In: Including Front AV : 5
        • HDMI In : 9(1) - 2 inputs for audio
      • Inputs and Outputs Video Outputs
        • AV Out: Inc. Monitor Out : 2
        • Composite Video Out: Inc. Monitor Out : 1
        • HDMI Out : Output x2 + Zone Ont x1
    • Video Features
      • Video Features A/V Sync Features
        • A/V Sync auto mode : Yes
        • A/V Sync Sampling Frequency : 192kHz
        • A/V Sync Time (msec) : 0-1200
        • Power Off Pass Through : Yes
        • 3D over HDMI : Yes
        • HATS for HDMI : Yes
        • DSD : Yes
        • BRAVIA® SYNC™ (CEC Control) : Yes (One-Touch Play, System Audio Control, System Power Off, Theater Mode(No button on RM))
        • S-Select : Yes
        • Audio Return Channel : Yes
        • Audio Widget : Yes
        • HDMI Version : 1.4a
        • HDMI™ video output capability : 4k,1080/24p, Deep Color, x.v.Color (xvYCC)
        • Video Up Converter (Analog Component/HDMI) : Yes (Analog component and HDMI)
        • Video Down Converter (Analog to Analog) : Yes
        • Video Up Scaler (Analog; Component/HDMI) : Yes(1080i and 4k)
      • Weight and Measurements Weight and Measurements
        • Receiver Weight (pound) : 39lb 11oz
        • Receiver Dimension (WxHxD inches) : 17 x 7 1/2 x 16 5/8 in
It's rear panel is sexy, well populated. Analog inputs ! Love that. But it's a dad-gummed Sony... I wish Harman Kardon would come up with something like this and a traditional A+B power supply. *sigh*
Sony's audio efforts are nowhere near what they should be, though. The content side of the corporate structure has far too much pull, and they put to many restrictions on the electronics' guys.
Stupid stuff like "Walkman" software not supporting Flac until late 2014... A multi-thousand dollar digital media player for digital files on networks, while installing rootkits, and software obfuscating attempts at ripping CDs to computer and network storage. It converts everything, even lossy sources to DSD, but I can't back-up my SACDs. I wouldn't even dare to connect it to my network. There's no telling what shenanigans they'll be up-to, but I suspect it's likely that file deletion/watermarking and data-sniffing stored content is certainly not above Sony's shabby , back-alley thugs' ethics. We are talking about a company that broke privacy laws, and showed what I, and most of my friends and peers, consider highly criminal behavior by compromising people's computers without any right to do so.
Sony's all over the place, with half the company (hardware) trying it's best only to be shorted by the other half (content). It's a two-headed hydra, not a company. As long as they don't realize that the two sides aren't in synergy, but in fact two waring faction within the same family, and put an end to this bull, Sony's threading water, waiting for a tide which will either bring it to shore (With a company split) or drown it for good (letting the content guys have their way and kill off hardware side).
just my two cents.
  • Agree
Reactions: KEW
great post and you hit it right on the head. It's too bad too because they have really good sound and this one in general looks very promising. I was shocked at the weight of it alone. If I could get my hands on one to test 1 I would love to put it through its paces. But alas I know they will not give out stuff like that for review they are so entrenched with Playstation they forget they have other parts of their company. Although PlayStation Store was just sold off to another company to run. Which is what they should do with their movie line goodness knows they lose a ton of money with that. I really enjoy my high end sony blu ray player and my ps3 too bad they don't know how to run a company
I don't think Sony sold off the PlayStation Store, they sold off Sony Online Entertainment which is their PC Division (PC Games) I don't think Sony would sell off one of their few profitable divisions, specifically because their cloud based game streaming service is such an integral part of the plan.
As for the Sony Receiver, I don't think any receiver should advertise 4K at this point if it can't do HDCP 2.2. We all know that is going to be the standard, and if it can't pass the signal, it's pretty much worthless for 4k
If Sony were smart enough to add Audyssey XT32 or ARC, more audiophiles might be interested. :D
If Sony were smart enough to add Audyssey XT32 or ARC, more people might be interested. :D
If they added DIRAC, the tweak'ers would have endless hours of fun.
- Rich
- Rich
I've never understood the correlation of DIRAC and meth addiction. :D
- Rich
Most "PEOPLE" don't even know what ROOM CORRECTION is.
Only AUDIOPHILES know about Audyssey, ARC, Dirac, Lyngdorf, etc.
Most PEOPLE would definitely buy Sony AVR regardless of Room Correction if the discount is more than any other major brands (Denon, Marantz, Yamaha, Pioneer).
The vast majority of Audioholics, AVSForum, and the other HT forums know about Audyssey as does everyone who gets the pitch form a sales person. I was unaware the hearing the term made you an audiophile. :p :D
Knowing when to turn it on and off might qualify though :D
- Rich
- Rich
An "audiophile" would know what the Audyssey is used for and turn it off in favor of tuning their system by ear because they have golden ears and that is obviously far superior to using measurements and a computer to establish an ideal listening environment. An "audiophile" would also make their final adjustments by installing a fancy cable to get the sound "just right". :D
Measurements are interesting.
A slight movement of MIC can have large changes in the response in the mid to upper frequencies. These difference are much greater than I perceive moving my ears to similar positions. Are they valid or measurement artifacts?
Most people who use Audyssey never see measurements. Some do it once, some do it many times until they like the sound.
I guess those who do it multiple times are the true "audiophiles". :p
In the end it is all about preferences, which is exactly what happens when a person does multiple calibrations runs.
The MiniDSP 88A thread has folks tuning to get the best flattest rules. Dirac tells me this is better and I spent all this money so it must be better ;)
I still use the original the monster cables for my main speakers. I am clearly not an audiophile :p :D
- Rich
ADTG, Rich, Seth, one of you please start a separate thread on "Most people" before the Pitbull shows you the teeth.
Too much of an undertaking to ask of us, one could go on and on for a lifetime on a topic such as that. :D
