O
oldtechuser
Wanted to alert refurbishers of this changer about a problem I've encountered with the Jog Dial. I have run into this twice in a row where the jog dial will not rotate the table for loading. What I discovered both times was a nick in the path on the circuit board, behind the faceplate, in the exact same spot. It's a hairlike path that associated with the Jogging control. I believe it is a defect in the circuit board when manufactured. I have been able to remedy problem by adding a jumper between the 2 connections between the path. FYI!
