Sony BDP350 or BDP550 for Denon 4306?
G
gwatkins
I am looking for an affordable blu-ray player to connect via HDMI with my Denon AVR4306 Surround Receiver and Panasonic 50" 1080p plasma TV. Is there any difference in the sound capabilities of the Sony BDP550 versus the Sony BDP350? Both seem to includes built-in decoding for Dolby Digital Plus and Dolby TrueHD. Thanks!
MatthewB.
The only difference is that the 550 has analog outputs (which isnt a problem since you are using HDMI) and the 550 can decode DTS-MA internally while the 350 transfers it to LPCM. If your reciever is HDMI 1.1 compliant you should be able to bitstream via HDMI all lossless audio signals (please double check this on me though, am foggy if it's 1.1 or 1.3 compliant, but pretty sure all you need is 1.1 I have the 350 hooked up to my Denon 3808ci and am bitstreaming everything and letting the Denon do all the decoding and I get all the lossless audio (even though the 350 cannot cannot decode DTS-MA)
