Sony AVR - on screen display issues...?
edwelly
edwelly
Hello all... I have a Sony STR-DA4ES - it is connected to my TV via components AND a S-video cable. HOWEVER, my on screen display no longer works. The onwer's manaul only makes mention that ON-SCREEN doesn't work with componet outs. I added the S-Video in hopes it would allow the on-screen part to work but I can't seem to figure it out. Any suggestions or is it not going to work with the components being used?
As always, thanks!!!
If you are using the two monitor out component and s-vid, then my guess would be that when you use the higher connection type, the lower one is disabled. Many receivers work this way.
I am not sure if this is the case for the 4ES. The OSD definitely worked with the S-video out but I never used the component video out at the time because I preferred to go directly to the TV. Just unplug the component out and you'll know right away.
