something comparable to beta 20's
snowmanstu1110
The beta's are a bit bigger than expected. I was wondering if there was something out there that would be comparable in quality but smaller. I was looking at the energy c-100's but didn't know if that'd be an inferior speaker.
Any recommendations? Was trying to keep it around $300 for LCR but max would go to $500.
Thanks
lsiberian
lsiberian
Thanks
Give the The speaker company a try. They have free inhome demo's
You might also see if a local musician store has some Behringer 2030p's
They are pretty big speakers.(It's why they go so cheap IMO)
Look around and you'll find something that works for you. :)
MUDSHARK
MUDSHARK
The Ascend CMB-170 may come in near the upper end of your budget for three. Definite upgrade over the Beta series (IMO) and probably about 15 pounds or so.
snowmanstu1110
yeah I think I'm going to try out something from the speaker company along with the beta's. Compare them side by side and see if the trade off of sound to size is worth it.
Robof83
Sounds like a good idea. Also you could look at bookshelf speakers from aperion. They have a 30 day in home trial and cover shipping both ways.
Also the Ascend speaker mentioned above is a very good reccomendation.
snowmanstu1110
Yeah, my first choice went starting to research was the aperion's but the price was just too high for me right now. So I figured I shouldn't even listen to them in case I really like them and want to keep :)
Patrick_Wolf
Patrick_Wolf
I've done a significant amount of A/B testing with the 4 pairs of speakers I'm auditioning right now (170, 2030P, TSBL, SBS-01) and I think the CBM-170 SE is my favorite. I really liked the Axiom M2, but I think I'm going to have to order the M3 and compare it against the winner of my personal bookshelf shootout (which will probably be the CBM-170). They all sound really good so it's a tough decision.
snowmanstu1110
Ok I purchased 2 Beta 20's and a Beta c250. Also, got the TSC TC2 center, TSC TSBL pair, and TSC P6-PR pair. The P6-PR will be the sound:size trade-off speaker if the size of the Beta's and TSBL are too much.
lsiberian
lsiberian
make sure you toy with your placement if you can. Sometimes you find those speakers that just sound terrific in a certain spot.
Robof83
Be sure to let us know your findings as I know I personally am very interested in this comparison.
Patrick_Wolf
Patrick_Wolf
Unfortunetly placement is limited, especially when two pairs are up there to a/b. And my usage will have to be nearfield so that's how I'm audtioning. Also I'm just using zone 2 on my receiver to connect the b pair and I can't level match zone 1 & 2 independently so I adjust volume using my ears; which really sucks, but I think I'm doing ok.
This is what I've got to work with for placement.
snowmanstu1110
Definitely will and I think I found a paradigm dealer fairly close by so I might just test a pair from there out too just for s.a.g.
