Some help please!!!!!!!!!!!!!!!!!
Simon Bogan
What receiver recommend to me?. I like Denon and marantz.
Room side is 16ft x 16ft. The speakers are Aperion, and would use the system for movies but for most music. There is a lot of the difference in sound between 80w and 100w? Which of the following systems you recommend?:
Denon 1708 525w 7.1, 1908 595 71 or 2308 700w 7.1.
And Marantz sr6001 and Sr4002.
Thank you for your help.
Thanks.
mazersteven
mazersteven
IMO you will not hear a difference between those receivers. Speakers make the largest impact in sound.
N
nick1000000
If it is mostly for music, I mould go with the marantz. They sound better with music compared to most receivers.
Seth=L
Seth=L
I would love to see the level matched DBT to back this statement up.:D
