Its not the Kenwoods
The problem is not with the 8 ohm Kenwoods, but rather the 4 ohm "cheapos" (your words, not mine
The 4 ohm speakers are causing the amp to go into and display OVERLOAD at higher volumes. Page 5 of your manual is poorly written, but clearly implies 8 ohms is the minimum impedeance required for speakers connected to this JVC amp.
TO FIX: Replace the center channel and two surround "cheapos" with 8 ohm speakers.
Cheers,
XEagleDriver
