Three-way Concerta F12 full-range speakers provide signature Revel timbral accuracy with astonishing bass and dynamic range. Occupying less than a square foot of floor space, the F12 creates a vivid, expansive soundstage and packs more than enough muscle to effortlessly reproduce any program peak.
Low frequencies, down to an impressive 28Hz (–10dB), are reproduced by dual
8" deep-anodized cone woofers with high power-handling voice coils and
flat, high-excursion spiders.
Midrange frequencies are exquisitely reproduced
by a 5-1/4" driver with a die-cast frame.
Lively, distinct highs from the 1" anodized Al-dome tweeter with CAI waveguide assembly are dispersed to precisely match the midrange, resulting in unprecedented seamlessness and coherence. The tweeter’s neodymium magnetic assembly features an underhung voice coil, ensuring linearity and low distortion.
The Concerta F12 is endowed with both the power and subtlety to bring any form of home entertainment stirringly to life.
F12
Sensitivity: 90.5dB SPL, with 2.83V @ 1m (4 pi anechoic)
Impedance: 6 Ohms (nominal)
Filter Network: 3-way high-order @ 575Hz and 3.0kHz
Frequency Response: In-room response: ±1.0dB from 58Hz to 18kHz Low-frequency extension: –10dB @ 28Hz Bandwidth: –6dB @ 40Hz and 45kHz
Recommended Amplifier Power: 20-200W
Dimensions (H x W x D): 42-3⁄8" x 9-3⁄4" x 14-3⁄8" (1074mm x 248mm x 363mm) (includes grille and feet)
Weight: 63 lbs for each speaker
