SnapAV Episode® All Weather Series Dual Input 5 in. Speaker (ES-AW-DVC-5) Overview
HTKamikazee
Audioholics Sheriff
Summer is just around the corner and it is time to get the outdoors set and ready to party. And what's a party without music? The Episode's new All-Weather speaker line from SnapAV offers the some pretty good options to choose from. Let's take their All Weather ES-AW-DVC-5 speaker as an example.
This speaker features one 5-1/4" Polypropylene cone, Nomex Spider, high temperature cone and dual 1" Aluminum dome tweeters. Its rugged build and weather-proof materials make this speaker an ideal solution for many applications. So, if you are looking for new speakers that you can leave outside without any worries, take a look at this one. Check out the following list of features and specifications for more information.
FEATURES:
  • Smarter Bracket = Easier Installation: Features slots on either end. Just mount the bracket, loosen the knobs on the speaker, and slide it on. Included rubber gaskets attach to the slots to hold the speaker once it’s mounted, and ribs along the edge to increase stiffness.
  • Gold-Plated Binding Posts: This speaker features gold-plated 5-way binding posts that are easy to use and provide secure connections.
  • Weather-Resistant, Rugged Build: Polypropylene woofers, aluminum tweeters, aluminum grilles and brackets, a UV-treated, mineral-filled Polypropylene cabinet, and stainless steel bolts the main materials used to build this unit.
  • Quality Components: Designed for optimal audio quality in wide dispersion distributed audio systems, this all-weather speaker features a slew of top-notch components, including a 5-1/4-in. Polypropylene cone with Nomex spider, a high-temperature voice-coil, and a 1-in. aluminum dome tweeter. It can operate effectively in even the harshest environments, from bitterly cold Maine winters to blazing hot Arizona summers.
SPECIFICATIONS:
Let us know what you think about this speaker!
