Hello,
I started some serious research on components and HT install. I started by getting quotes from others and posting to this forum. Thanks for the help to this point, but after researching, I'm going the route of a minimal setup but doing it on my own. I'm a rookie, but like to learn and hope you all will share some expert advice.
My main goals in this mini project are to:
1. purchase a receiver
2. purchase and install indoor volume control
3. purchase and install outdoor speaker
I will need the most assistance with identifying the correct cables to connect to the receiver, the volume control, the outdoor speaker and figuring out how to connect them.
I have two areas in the living room where the wires are covered with face plates. When I remove the face plate to the wires I plan to use, I see the following (the other set is identical as the wiring crew set up the room so the entertainment center could be in one of two locations):
5 wires total
2 Purple - inside each are two shielded cables - black, red
1 Gray - CAT5e
2 Blue - inside each are four sheilded cables - red, black, green, white
There is already a CAT5 connection for Internet in a jack next to this face plate, but I guess you can never have enough CAT5 running around.
There is another face plate upstairs right by the patio door which I was told is for volume control for the speaker directly above the patio door on the outside. When I open this face plate, I see
One blue cable that appears to be the same wire as what is sticking out above the door outside and does not seem to come from downstairs
One gray cable seems to come from downstairs and comes out to an end from this face plate
Two purple cables come from downstairs and come out to and end from this face plate
On the patio, the blue cable sticks out just above the door. Obviously this is where I would hook up the outdoor speaker.
So, I would greatly appreciate any thoughts on a cheap volume control, a mid to lower end outdoor speaker and especially any tips on how to install the volume control and how to figure out which wires to connect to my receiver in the living room so I can play sound out of my front speakers in the living room while also playing sound to the outdoor speaker with volume control.
I have not yet purchased a receiver, so any thoughts on that would be helpful too.
Thanks in advance.
