slp meter on avr-5803....
dtsfreak
hi,when calibrating the channel levels (slp meter)on my avr-5803 using dve disc should i use the limited bandwidth pink noise or the full bandwidth one??? :rolleyes:
I doubt it matters as you want each channels to match in overall level but since you have both band or noise, use both and see if there is a difference. ;)
dtsfreak said:
i did that and i get different readings when using full and limited...... :eek:
How different is it? A bunch or just a smidgen ;)
