Slim Center Speaker
ScHiZoPhReNi
Hi Guys,
new in here, so I hope I can get some help from some specialists in here :)
I'm going to buy a new television (Samsung UE55HU8500) next week, but since they are all so low from the feet my current center speaker from my surround set KEF 2005.3 gets in front of the screen.
I measured and the space I have for a center speaker is only 2.8 inches (7cm)
Anyone knows such a small sized center speaker ?
Since they make the soundbars so slim, there should be a center available also ???
thank you in advance !!
crossedover
crossedover
IMHO you shouldn't be looking for a small center, but a better location solution. Options include wall mounting display, credenza server, and depending on how far apart your L/R speakers are no center. In addition, using a non voiced matched center is far from ideal
BoredSysAdmin
BoredSysAdmin
I had 6.8" clearance for center and I had trouble finding one, good luck with 7cm
Mikey_seikou
personally id agree with moving the speaker's position, had my panasonic centre on top of my tv for over a year with no problems, if this is not a viable option for you at least half the sound bars out there are under 7cm or less. JIms idea seems quite sound! hope i've helped?
