Slim Center Speaker
amradel
I need a Slim center speaker with good performance for $50-$80
Any recommendation??
Midcow2
Midcow2
Def Tech
ProCenter 1000
Center Channel Loudspeaker to match with ProMonitor 800 or ProMonitor 1000 satellite speakers Dimensions | Metric :
14-3/4" W x 5" D x 5" H | 37.5 x 12.7 x 12.7 cm
Available Finishes :
Gloss Black; Gloss White
ParadigmDawg
ParadigmDawg
You need to get the one that is timbre matched to your LR speakers. Sometimes that includes making more room for the center to fit.
tomd51
tomd51
Ditto Paradigm Dawg's sentiment. In order to have proper panning from left to center to right and back again, you ideally want to have your center timbre match your mains.
Here's a small checklist for you to define so we can properly provide suggestions:
- What are the make and model of your mains (e.g. Infinity Interlude IL 10s, Boston Acoustics VR3s, etc.)?
- What are the size limitations of the space you're working with for your center (HxWxD)?
If you can provide these, we can provide a more suitable solution for you... -TD
