Slight glitch in RX6A6 Standby Setting
MarkBat
purchased this unit to upgrade RX2070. Love the sound and features. Primary use is home theater using tv source and Blu-ray, plus MultiZone music. Noticed that the unit would shut down while watching tv source at moderate level (-25-30dB). Checked to see if I had somehow activated sleep timer. No.checked internet posts for similar issues with other owners.No. Only posts were for circuit protection due to speaker wire shorting. Not an issue as I use banana plug connectors. Was looking around at features in the Yamaha Web Editor and saw that Stanby shutoff was set for two hours, so increased it to four hours as I rarely watch more than three hours of tv at a time. Problem disappeared! Can only assume that with tv source (Hulu, Netflix, prime) and pass through on for video processing , system doesn’t recognize the signal and and goes to standby mode after the preset time. Problem never occurred when using multi zones and MusicCast playing through out house and outside with Pandora source. Just a programming glitch I guess.
ben_
ben_
I actually have a similar issue with my cheap Yamaha R-S202.
MarkBat
Is there any way to increase the standby time out time? I think the Aventage line is the only one that has web editing features so you might have to do a deep dive into the sub menus on the set up screen.
