kellyk75 said:
That is very nice of you Pyrrho, but just the mention of "state" and not "province" means you are too far to come and listen...... eh!
However; I did some experamenting last night, covering the tweeter, port etc. while listening to really the only audible problem I could find in 3/4's of disk one of "the two towers"... the scene where Gimley gets threatened by the Rohan exiles (geeking out). That could be the speakers (or the movie). I was doing some exploritory surgery on the centre channel & turned my TV speakers back on while the receiver was off..... I watched TV and the TV speakers had the same problem to a lesser extent. I could tell it was less because the tv speakers are much less sensitive than the Athena's. I also noticed that some channels are worse than others, mostly higher channels. Comedy & Cartoon network are pretty bad.
Long story short, I guess there could be a problem with my cable connection and what I heard on the DVD's was either slight sillibance or possible sound engineering flaws. I will have to start watching more movies and see if I have this problem anywhere else. I did notice season 1 of "24" had this problem, but it is rendered in 2 ch AC3. Why does it happen while gaming on the PS2?!? Who knows. I guess time will help figure it out.
If anyone has any advice on fixing the cable problem, or if they experience PS2 noise, I could use it. I will "play" a little more and post my findings. Maybe others will find this thread as usefull as I have. Thanks again.
This is an interesting statement that very much supports what I have been saying:
"I watched TV and the TV speakers had the same problem to a lesser extent."
As I said, many speakers do not render speech well.
As for some channels having the problem more than others, there is no reason to suppose that any two channels precisely process the audio the same way. For announcers in commercials, it is very common to apply extreme equalization to give the announcer's voice the desired tonal quality (desired, that is, by those who make the commercial). A TV station can boost any frequency they want and apply that to everything they broadcast, if they want. They know that most people just use the speakers built into their TVs, and so they may decide to equalize the sound accordingly. Other stations may take a different approach. Of course, before the station gets the TV show or commercial, the people making it applied whatever processing they wanted to it, so you can have many layers of processing applied to the sound before it ever comes to you.
What does all of this have to do with your problem? By emphasizing some frequencies and not others, if they emphasize whatever your speakers are not good at, then they aggravate your problem.
Again, there is nothing "wrong" with your equipment. You know it isn't your receiver or main speakers, because it happens without them (through just the TV). You know it isn't the TV, because it happens with its speakers off and the audio being sent directly to the receiver from your DVD player. You know it isn't the cable, because it happens with DVDs. You know it isn't the DVD player because it happens with the cable. So what is it? It is this: Some speakers are not good at rendering speech. Your speakers, both on your TV and in your home theater, are not good at rendering speech. Really, this should come as no surprise, as all speakers overemphasize some frequencies, and underemphasize others (if they did not, they would have a perfectly flat frequency response, or practically so, like an amplifier: 20-20kHz, +/- 0.5 dB, which is flatter than you are ever going to have with a speaker). Additionally, all speakers distort, and they distort so bad pretty much no speaker manufacturer lists it as a specification, because people might compare it with amplifier specifications and be appalled at how dreadful they are by comparison. When a speaker is sent a tone, it reproduces not only that tone, but frequencies both above and below it. All speakers do this. What matters is how much it does it, what the frequencies are, and so forth, which distinguish one speaker's sound from another.
