No posts in this thread for a while, so I wanted to give an update.
I have been using this gobo amp built from a kit (I paid $100 for the kit, less than the current asking $160)
https://www.boxedkitamps.com/gobo-stereo-audio-amp-kit
With a Parasound ZCD in silver (used off ebay for $225)
http://www.parasound.com/img/zcustom/zcd_angle_silver.jpg
And the DT SM350 (new from newegg, I paid $200)
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325059&cm_re=definitive_350-_-82-325-059-_-Product
For
$525, this is an incredible little desktop setup! I actually use it at my workbench where I work on electronics projects and repairs, where space is at a premium.
I can turn this system gain up to max with the cd paused, and I get absolutely no hum or hiss from the speakers, even with my ear right up to it. I can also turn the volume down to min and put my ear up to the ZCD and just barely hear the disk spinning. That is no trivial feat!
The
Parasound ZCD: A
FINE CD player! Small so it is easy to move between amps or rooms, and that is important if you build audio gear, or have limited space. It also has the option of fixed or variable outputs, another great option for an amp builder. It is completely
QUIET. I can BARELY hear it spinning when I mute the audio and put my ear right up on it. If I had to nitpick, slot load drives aren't my favorite, but I'll let it slide for everything else that it does right. A great deal for the $225 that I paid!
The
GOBO from BKA: A great little amp! Small and it looks snazzy and it puts out a real ~20Wpc (8 ohm). It's not a beast or anything, but it does its job well and has
no hum or hiss! There are 2 nitpicks to add: 1) It could use a subwoofer out. 2) There is a "thump" through the speakers when it powers down. That has kept me from running the Philharmonitors on this amp. It needs soft-start / shutdown. I am currently working on an external speaker protection circuit that should solve this problem. For the $100 that I paid for this amp, good luck finding anything better at that price point (it aint gonna happen).
The
DT SM350: Good, small speakers. Sure, they are probably not the most accurate out there. For the $200 that I paid for them, they are worth every penny! Even if not the most linear FR, they do sound good to my ears, and they are an easy load to drive, and they have better deeper bass than I expected (room placement helped on that).
I will most likely be moving the GOBO to take on duties for my drum machine / synth setup, feeding P363 towers. The ZCD will move to my Parasound 1206, and eventually to my reference level LM4780 amp (once it is completed), driving the Philharmonitors. That leave the DTSM350 as "floater speakers" for a while, and will eventually be paired up to a LM3886 build.
