SLI Dual Video Card Question
Rickster71
Rickster71
Hello all,
I have a question concerning adding a second graphics card in SLI.
My original card is:
EVGA GeForce GTX 670 Video Card - 2GB
The second card I'd like to buy:
4GB
With the only differences being the memory, (in red) will that cause any problems/incompatibility?
I'm having trouble with what specifications have to be exact matches and what ones don't.
I can't seem to find another 2GB card under $400.
Thanks for any help!
lsiberian
lsiberian
I've never done SLI, but I'm betting you'd be fine. That said why do you need the upgrade?
Rickster71
Rickster71
I've heard that all the cool kids have two graphic cards.
But seriously though; I'm up for anyone talking me out of spending money.:D
I play a video game every winter, and have a monitor that I can adjust the refresh rate up to 144Hz. Planning to go to 2 monitors for work also.
Hoped to get the smooth graphics like they show on the game commercials, to help me fit in with the cool kids on the block.
Adam
Adam
What resolution do you run?
For work applications, unless you do really graphically-intensive work, your current 670 will be more than plenty to run two monitors. For gaming - make sure to check that your game(s) will let you use multiple monitors before ponying up the cash for another card. For example, StarCraft II will blank out the second monitor (unless you get third-party software, which I haven't).
Rickster71
Rickster71
Resolution = 1920 x 1080.
I notice when I turn up the refresh rate to 144Hz the screen gets a little smaller, not 100% full screen. So I reset it back a notch 120Hz.
Rickster71
Rickster71
You could mix 2 and 4gb card, but the baseline usage of video ram will be based on 2gb card - aka extra 2gb on 4gb will be wasted
Considering SLI - Nvidia - Graphics & Displays
On the other hand what games you play and what is your screen resolution?
Do you even need sli - keep in mind NOT all titles will gain from it and b) don't expect linear performance increase
NVIDIA GeForce GTX 670 SLI Review | techPowerUp
The games vary, since I refuse to pay full price, I'm a little behind the curve.
In the past it was Mass Effect 3, now Fallout 3. Maybe Metro next, or Bio-Shock Infinite.
I have it in my head I'd get the resolution I see in the gaming commercials. :eek:
Adam
Adam
I think that Bored and I deserve a commission for talking you out of buying that second card. :p
Well, or you could just buy that Oppo 83SE for Alex. :D
Adam
Adam
What resolutions are they running? Perhaps something beyond what your monitor can do?
1920 x 1080 isn't super high resolution, depending on the screen size. For example, the Apple 27" monitor is 2560 x 1440.
Adam
Adam
Ewww, ahhhh. Newegg has a couple of 3840 x 2160 monitors. You should get one of those.
There goes my commission...
Rickster71
Rickster71
I'll have to pause the TV next time I see a game commercial, maybe it's in the fine print/disclaimer.
My screen is 24"
I've never really seen anyone's monitor to know that they're getting better graphics than I am.
I just assumed it was supposed to be as I saw in the commercials.
BoredSysAdmin
BoredSysAdmin
Well on this list only Metro strikes me as power hungry beast. On sole GTX670 For smooth full hd fps you'd need to lower quality a bit (or get a 2nd one :) haha )
Get Skyrim ! :)
btw: did you played Witcher 1 and 2 - you should be find both on sale
Rickster71
Rickster71
Any game recommendations? I tend to like shooters.
What's Skyrim like?
Rickster71
Rickster71
I have to run.
I'll be back a little later.
Thanks!
BoredSysAdmin
BoredSysAdmin
Skyrim is First person RPG - it has great graphics, huge world and very, very deep story line.
Witcher is quite similar
They both somewhat similar to Fallout (and a bit less to Mass Effect which does have light RPG elements)
lsiberian
lsiberian
My screen is 24"
I can't imagine gaming on a small screen anymore. I'm so spoiled. Why not get a 40" tv and use that for a monitor?
I run CAD streamed via a client that is probably as active as a shooter or worse, and we don't use dual cards :) Oh and I work a block from Nvidia :D
panteragstk
panteragstk
I've got a 760 gtx that works very well for my 1920x1080 resolution. As far as shooters go, I like the Metro series. I used to love Medal of Honor, but I think they are done making those. Steam is a great (and terrible) place to find all sorts of cheap games. They steal a lot of my money.
