Yamaha DVD-s657
jeffvee said:
I'll check it out. My speakers are set to small, so is what you are saying good or bad?
Also, does the 657 have faster load times?
J Garcia is right, ...sorry, i don't think i was clear... the players "speaker settings" only applies when using the analog 6 channel connections for SACD and DVD-Audio.... If set to "small", the cut-off is 120hz.... and if set to "large", you will be sending full bandwidth to your speakers.... The Freq cut-off on the s657 is not adjustable.... I am connected to my Yammie RX-V757(a/v receiver) by an Optical Audio connection right now... where the Receiver makes the decision to where the Cut-OFF is (right now, all my speakers in my receiver are set to "small" and my Cut-Off is 80hz, this is a common set-up)...
...Let's say i had the 6 analogs connected.... The DVD Player will use it's "speaker settings", and "Cut-OFF", only when I play a DVD-Audio or SACD.... (this only happens when the player detects a DVD-A or SACD)...
now, all this being said.... there are people that will say 120hz is a high cut-off setting..... is it??? who knows..... music listening is different from movie listening..... like you said, the C750 got great reviews, especially for it's multi-channel playback ability.... C750 has the same fixed 120hz cut-off...
i'm sure you read this review...
http://www.audioholics.com/productreviews/avhardware/YamahaDVD-C750DVDChanger1.php
.... the review does mention that a "CON" is the fixed 120hz... but if you look at the SACD evaluation of the review... the reviewer sounded impressed.
like i said before, i've heard many say that the s657 is a single disc version of the c750.... I Don't know if it is true, but, ALL the specs for both players are identical..... the menu screens and remote are ALL identical....
...now, as far as load time??????? I have not observed the load time being long.... I'm not sure what you are used too..... but, in my opinion, It loads a disc in good time..... you may have to go to a store and check this out for yourself....
final note...... For sure there are better players out there..... but for 200 bucks.... it's pretty good, i think!
...plus, it comes in Black
hope it helps,
greenhill
