Hey Guys,
I have a bit of a problem. I recently upgraded my speakers to a Wharfedale Diamond 5.0 set (i'm still saving for a sub). Now, my surrounds are diamond 9.1's weighing about 15-20 lbs. I place the RR one on a floating shelf running down the side of one room.
When I walked into the room this morning, I discovered that the shelf has sagged overnight! So I pulled the speaker off immediately.
Now I need to build some sort of stand for the speaker. I have a screwdriver and a drill, and can get timber and MDF cut to size at the local HW store. Do any of you have a link to a "How To" guide or a DIY walkthrough or something? I'm a crap carpenter, so the simpler the better, but as long as I can spray it black and it looks neat I'll be happy.
And now I have to figure out how to fix the bloody shelf too, but that's later's worries.
