Hello, Ive been considering updating my home theater system. I had a buddy tell me how his Bose cinemate II works. You basically have 1 wire you hook up to the TV, and the system works with everything thats hooked to the TV...XBOX, Direct TV, Blu ray player etc...Theres no receiver that you have to hook each component up to and theres no buttons to have to push to pair the right component either, the audio is just there. Basically it sounds as if the TV works as the receiver. I recently discovered that there are sound bars that work like this as well....my question is, is there a 5.1 or 7.1 theater system that works like this? ..Or is there a receiver or set up that will allow a set up like this? like a sort of extension from the tv speakers? Finally, even a receiver that will auto detect the component being played would be good? I just really like the idea of having my TV and components all working through a home theater system with as few a steps and processes to do when switching from the TV, Xbox, PS2, etc......I also like the idea of having as few of wires as possible. Any ideas?
