Simple(?) Newbie Cable Question
I
incubeek8
Hi,
I have a mac mini with a "combined optical digital audio output/headphone out" and a set of Swans M200 speakers with a dual RCA input on one speaker. It is my understanding that using digital audio output rather than a regular 3.5mm miniplug would give me better audio quality (because the digital/analog conversion is not done in the interference laden computer). So, if this is in fact true, is there such a thing as a 3.5mm digital to dual RCA cable, and will this actually improve the sound from the speakers? Is there a better way of getting the signal to the speakers that I am not aware of?
Thanks in advance for any help you can provide, and if anything is unclear i'd be happy to attempt to clarify.
Adam
Haoleb
Haoleb
The inputs on your swan speakers are made for analog inputs. You would need a DAC (digital to analog converter) between the computer and the speakers inputs if you are going to set the mac's output to digital. As you already know most stock type computer soundcards arent really the greatest. Some are though. There are also USB type external soundcard devices. I assume you need a special type of plug and converter box to get the digital output from the mac as a standard optical connector will not fit into a 1/8" mini jack.
MDS
You cannot convert from digital to analog or vice-versa with a cable - active electronics are required (as described by haoleb).
I
incubeek8
Thanks
Thanks for the input, i see what the problem is. Anyone know of a good, inexpensive DAC (USB, TOSLINK, or other)?
Seth=L
Seth=L
If you can find one of the external audio cards, get one that has Firewire (the mac Mini is sure to have a firewire port). If I had the option I would use Firewire over USB if for nothing else but a higher bandwidth capability.:)
I
incubeek8
Thanks again
Thanks for the ideas, I'll research some and see what I can find.
