Signal strenght meter on a receiver?
V
videobruce
Do ANY receiver have a FM signal strength meter?
If not what Tuners have them?
V
videobruce
Still looking for an answer..............
There are NO receivers that will tell you incomming signal strenght??:confused:
Then how do you orentate your antenna?:rolleyes:
Hi Ho
Hi Ho
I do not know of any modern receivers that have a signal strength meter. My old Quadraflex did but that was from 1977.
I used a directional antenna before I subscribed to cable TV (which has all the FM radio signals). I never had to move the antenna to get good reception on my old or new receiver.
markw
Come to think of it, I can't recall the last time I saw one of these on a receiver, aside from this one.
http://www.magnumdynalab.com/md208.htm
I used my trusty old Marantz 2270. If FM is that crirtical to you then I'd suggest you shop around for a used analog tuner.
jcPanny
jcPanny
These days, we get that little LED to tell you when it is locked onto a station. LED OFF or flashing and static == Low signal strength.
Just kidding. But seriously, you could brobably get one of those 1970 tuners and use it to adjust your antenna.
V
videobruce
Really going backward here..............the same as not having a speedometer on a vehicle.:mad:
