Signal output question
ThA tRiXtA
ThA tRiXtA
Hey Guys
Just wondering.... I have a sony 300 disc player and other equipment hooked up to my Onkyo TX SR 701 receiver.
They are hooked up using digital optical connections.
When ever I am listening to a cd the receiver says that it is receiving a pcm bitstream.
Is this the correct format or is there another output that is better?
Thanks for your time.
Z
zumbo
Yes. That is correct. It is my understanding that the PCM is 2-channel, and DD or DTS is multi.
PCM (pulse code modulation) A conversion method in which digital words in a bit stream represent samples of analog information. The basis of most digital audio systems, first invented by Alec H. Reeves in 1937.
markw
PCM is fine for two channel applications, which is all that regular (redbook) CD's offer.
Now, if this was a DVD player, you would want to choose "bitstream" in order to avail yourself of lti channel DD and DTS movies.
