Shure SRH1540 Premium Closed-Back Headphones Overview
HTKamikazee
Audioholics Sheriff
As you might now by now, I've been a headphone fan since I was little. That's why I've been doing several headphones overviews this week and there is one that I simply can't leave behind.... The Shure SRH1540 Premium Closed-Back Headphones.
The SRH1540 is a full-size, circumaural, sealed headphone built with a very nice mix of synthetics, carbon fiber, aluminum, and steel. Ear capsules are black plastic with a large, carbon-fiber outer panels with the Shure logo on them. They feature Alcantara (memory foam) ear pads with large openings (62mm x 45mm) and are deep enough for most ears in order to offer maximum comfort and sound isolation.
Its cable is a six foot OFC "Y" cable that connects to the bottom on both ear pieces with MMCX coaxial, snap-on connectors, and is terminated with a threaded 3.5mm stereo plug on the other end. An 3.5mm to 1/4" adapter is also included. It is important to note that the headphones are non-folding to make them more compact, but a hard-shell case is also included for easy storage. As a nice detail from the company, a second identical spare cable and ear-pads for the headphone are also included. Take some time to check out the features and specifications below and let me know what do you think about the SRH1540. Will you give them a chance?
FEATURES:
  • 40 mm neodymium drivers deliver superior acoustic performance for an expansive soundstage with clear, extended highs and warm bass
  • Diaphragm developed with APTIV™ Film for improved linearity and lower THD (total harmonic distortion)
  • Closed-back, circumaural design rests comfortably over the ears and reduces background noise
  • Lightweight construction features aircraft-grade aluminum alloy yoke and carbon fiber cap for enhanced durability
  • Steel driver frame with vented center pole piece improves linearity and eliminates internal resonance for consistent performance at all listening levels
  • Ergonomic dual-frame, padded headband is lightweight and fully adjustable for hours of listening comfort
  • Oxygen-free copper cable (OFC) with Kevlar™ reinforced jacket offers superior performance and durability
  • Dual-exit cables with gold-plated MMCX connectors provide secure connection and can be detached for easy storage or replacement
  • Replaceable ear pads feature Alcantara and low-density, slow-recovery foam for exceptional comfort
  • Legendary Shure durability allows the SRH1540 to withstand the rigors of everyday use
SPECIFICATIONS:
  • Sensitivity: 99 dB/mW
  • lmpedance: 46 Ω
  • Frequency Range: 5 Hz – 25 kHz
  • Weight: 10.1 oz
  • Cable Length: 6 ft
  • Cable Style: Dual-exit, detachable oxygen-free copper
  • Plug: Gold-plated 1/8" (3.5 mm) stereo mini jack
PRICE: $499.00
