Carl08,
I believe using the speaker high-level signal inputs/outputs to connect your Superzeros may achieve what you want.
However, I took a look at the M8's manual and could not find any statement definitively stating the speaker high-level outputs do in fact pass through a high pass filter (fixed or variable).
- The Crossover Frequency knob's function is described in the manual as follows:
"LOW-PASS CROSSOVER CONTROL"
"This control sets the frequency of the built in variable low pass crossover"
Some subs have an output signal path that does pass through a high pass filter (typically a fixed value) and the manuals are very clear about this (i.e. my SVS SB12-NSD).
- On my SB12 this HP out is provided for a low-level signal that I feed back into my reciever (a HK 3485) which has no bass management, but does have stereo Pre-amp Out/Amp In connectors/bridge.
Therefore, I think the connection scheme you propose will probably divert low frequencies to the sub only and away from the Superzeros, but I am not sure.  At worst you would be no different than now with the Superzeros receiving a full-range signal from the NAD.  I would advise giving it a try.
Cheers,
XEagleDriver
