Should I upgrade my subwoofer? - Polk Audio PSW650
SUPERTANK
I have a Polk Audio PSW650 and while is sounds great and rattles my walls, just wondering how it compares to newer 2009 - 2010 models?
I just upgraded my center and towers, should I upgrade the subwoofer as well or stick with the one I have?
bandphan
bandphan
Id look into another brand if you really want to improove your bass;)
SUPERTANK
suggestions? which brand...
Is MARTIN LOGAN ABYSS good?
GlocksRock
GlocksRock
SVS subs are regarded very highly on this forum. I would definitely check them out, if it's in your budget then jump on one, even their entry level PB10-NSD is leaps and bounds better than most 10" subs on the market.
jeanseb
jeanseb
+1 here
I agree with Rock.
chris357
chris357
again what is the budget ? I have the Epik empire and it is an amazing value.
AVRat
AVRat
Also need your room size? I'm thinking that with a 104" screen I'd want something on the order of an SVS PB12-NSD or larger.:D:p:cool:
SUPERTANK
Looks like a good sub; not a bad price either! Will this hit pretty hard like vibrate my couch? I looked into the buttkickers a few years ago :D
