Should I Sell My Speakers And Buy Something Else?
SunnyOctopus
SunnyOctopus
I have a pair of KRK VXT 6:
http://www.krksys.com/krk-studio-monitor-speakers/vxt/vxt6.html
And the KRK 10S Subwoofer:
http://www.krksys.com/krk-subwoofers/10s.html
And a SPL meter and some sucky Auralex acoustic pads.
I bought everything for about $850. Should I sell everything for $1000 and buy other things? I believe in objective audio quality, and that's my aim, but the speaker setup for me is kind of tiring. It's big, complicated, and eats up alot of space, and I feel bad because the speakers aren't in a perfect equilateral triangle, they're not aimed 60 degrees, and I have no room treatment. I hate how I can't listen at night with speakers, and there is always external noise when I can listen. I want to be isolated away from that. Also, I live in a earthquake heavy location and figure it's only a matter of time before they kill my speakers. Do you think I should sell all my equipment and start fresh? What do you recommend? Right now, I'm thinking of just buying
http://www.krksys.com/krk-headphones/kns-8400.html
Plugging them straight into my soundcard, and putting the rest away for a rainy day. What do you all think?
Thank you for your time, energy, and input!
BEST WISHES!
bikdav
I bought everything for about $850. Should I sell everything for $1000 and buy other things? I believe in objective audio quality, and that's my aim, but the speaker setup for me is kind of tiring. It's big, complicated, and eats up alot of space, and I feel bad because the speakers aren't in a perfect equilateral triangle, they're not aimed 60 degrees, and I have no room treatment. Do you think I should sell all my equipment and start fresh? What do you recommend? Right now, I'm thinking of just buying
BEST WISHES!
The existing system that you have is nice. I do not think parting with it is a good option for your mentioned reasons. With the information that you provided, it sounds to me like you need to experiment with room placement _ or maybe move the system to another room [if either of those are options]. Headphones are great for portable use or in situations where music and room noise might interfere with one another. But, I wouldn't recommend them for the only listening source. I'm not aware of anyone who likes being "isolated" in headphones for hours at at time.
