Hello All,
I bought a set of 5 SCS-01s & a 20 39PCi sub circa 2007, and never really used them.
I can't find specs for them on the SVS site, but linked the closest I could find.
Home Theater Systems and Audio Components | Audio Visual Equipment Product Reviews, Technical AV Guides, Home Theater Equipment and Product Reviews
hometheaterhifi.com
SVS Model 20 39PCi Subwoofers user reviews : 5 out of 5 - 32 reviews - audioreview.com
www.audioreview.com
They are 87 sensitivity, 120 watt, 8 ohm. Are they considered good speakers, or would it be better to buy new?
If they aren't, the recommended system is in my price range.
We put together a budget friendly 5.1 recommended home theater system for $750 that will crush any HTIB or soundbar, especially for music. Get this if you're an audiophile on a budget.
www.audioholics.com
Thanks, Russ
