Shopping for a Blu-Ray player, need advice
jnl67
I am looking to finally ditch my Sony DVP-NS300 DVD player and upgrade to a Blu-Ray player.
I am partial to Marantz, as i have there SR7500 receiver (Yes it's older, but still a workhorse). While i am not brand exclusive, i do like the Marantz Blu-ray players. Unfortunately there Blu-ray flagship is out of my price range at $6000.
So brand loyalty aside, can someone help identify what aspects and specifications such as Video DAC, Audio DAC etc...to concentrate on when comparing players. Shopping in the $200-$500 range.
Thanks,
Jim
jostenmeat
easy
Oppo BDP-83 at $499.
If you really care about the DAC thing, get the SE version for $300 more.
If you don't care about SACD/DVDA, and would like to spend less, I would recommend the Panasonic DMP-BD80 for $180.
lsiberian
lsiberian
Thanks,
Jim
I'm a cheap skate and suggest you wait until black friday at this point. Black Friday is when all the prices reset on electronics. If you can't wait two weeks just look at Amazon and you will see a whole host of them going anywhere from 120 to 300 dollars. I use Panasonic DMP-BD60 and it works very well, but it doesn't pass through 480i(stretches old tv shows) and that is it's worst down fall in some setups.
dc6
Picked up an Oppo a few months ago and it is worth every penny at 500$
jnl67
So my December issue of Home Theater magazine arrived yesterday, and it just so happens to be the Blu-Ray special, so i have plenty to look over...
My main question is, what separates the men from the boys spec wise as far as blu-ray players go? I obviously am not going to buy the cheapest model at Best Buy or PC Richards...but i want to be able to know that i am buying a Porsche, not a VW bug with a Porsche body.
jostenmeat
I imagine it will mostly be about features. That should be helpful to you.
There aren't any really to help you, as far as "specs", outside of feature lists.
IMO, the biggest factors are:
- reliability, not just of the player, but of playback. IOW: FW support
- convenience factors, such as quick load, easy updates, etc
- PQ lastly, and the reason I say "lastly" is because all of the decent players are very close to each other in performance. The biggest leaps and differences you will see is with the software itself.
Now, the best way I think to learn about PQ differences is with published tests/results/shootouts.
For instance, here is an old thread I started with a 6 BDP shootout, replete with HQV test results.
http://forums.audioholics.com/forums/showthread.php?t=47892
If bonus features aren't necessary, and you want to spend less, Panasonic has had top of the line FW support, reliability, and implementation/ease-of-use. Now, if you need any certain feature, then you have to decide for yourself.
