The very best in your price range.
Hi, and Welcome to Audioholics Home Theater Forums, where the couch is always warm and the amps are running warm too.
First, let me ask you this: Did you read some of the other threads about the same type of question than yours, with some of the best recommendations on the business?
Because if you did not, your answer is just couple clicks away.
Just a very simple suggestion. Because we are just repeating ourselves over and over.
* About sending all the bass in the rear or surround speakers, just forget it, there is no such receiver in the $300 price range, let alone in the $3,000 price range. Your best bet is the subwoofer.
#1. Your best option is to get a sub.
#2. Your 2nd best, is to trade your back surround speakers with your two side front ones.
#3. Then you can choose the receiver. But option #1 is definitively the one that you should highly consider first. So now, I don't know anymore if you have money left for the receiver. But anyway, shall you go with option #2, a good receiver in the $300 price range with the features and the quality sound on music that you're asking for, would be something like a Marantz SR5002, that cost $349.99, only $50 more than your budget, but it's highly worth it for this small difference.
1* SR5002 ->
http://www.accessories4less.com/make-a-store/item/MARSR5002/Marantz/SR5002-receiver-90w-x-7ch-HDMI-home-theater-surround/1.html
>>> Just scroll down a bit.
Also there is the Onkyo TX-SR606 for only $319.99 at the same place.
2* TX-SR606 ->
http://www.accessories4less.com/make-a-store/item/ONKTXSR606/Onkyo/TX-SR606-90w-x-7ch-HDMI-Theater-Receiver-BLACK/1.html
And the Yamaha RX-V465 is only $259 at 6th avenue. You just put your price by clicking on the yellow star "Price Alert" in the appropriate box (Price Target) and your e-mail address, and then click "Submit", that's it. They will contact you to say that they accept you offer of $259.
3* RX-V465 ->
http://www.6ave.com/shop/product.aspx?sku=YAMRXV465
>>> Don't be worry about the indicated price of $329.00, just make your own price in the Price Target, click on the link just below, you'll see (if you're interested in the RX-V465 of course). But for only $259 and 4 HDMI, why not.
** RX-V465 Price target:
http://www.6ave.com/shop/PriceAlert.aspx?id=YAMRXV465
So here you go, three of the very best ones for their price, between $259 and $349.99. Just check their feature's list and specs plus number of HDMI inputs and versions, then pick the one that fits your needs. You'll get all of this information in their respective web sites.
Cheers,
Bob
