Setup Question (Secondary S/W?)
hometheaternoob
I have another couple of questions about tweaking my setup...
Here is what I am currently running in my home theater, which is in my living room:
TV: LG OLED C9 65"
AVR: Denon AVR-x4500h
Center: Klipsch RP-504c
Front: Klipsch RP-8000f
Surround Side: Klipsch RP-400m
Surround Back: Klipsch R-41m
Height: Klipsch RP-500sa (on top of the 8000f speakers and upward firing.)
S/W: SVS PC-2000
I have 2 questions..
1. I have my setup with the front speakers set to small and making full use of the S/W. With the power of these speakers, should I be using LFE+Main? My assumption is no, to leave them set as small and have s/w just do its thing.
2. I have an old old s/w in my garage from my previous speaker setup. Its part of the q-line set from SLS, SLS qg5000,Its a 200w woofer. Should I add this to my setup to add a second s/w or is that silly since it is not as good as the SVS PC-2000?
Thanks guys.
Noob
Just call it a sub rather than s/w :) Setting to LFE+Main is more a preference thing, some like that thickening/overlap of bass. Experiment.
I'd probably pass on using the HTIB sub and concentrate on setting up the PC2000 as best as possible.
L
Leemix
TV: LG OLED C9 65"
S/W: SVS PC-2000
Thanks guys.
Noob
1. Small and LFE only yes.
2. No it would only mess up what the SVS is doing.
William Lemmerhirt
William Lemmerhirt
TV: LG OLED C9 65"
S/W: SVS PC-2000
Thanks guys.
Noob
1). No. Just use LFE.
2). Leave the other one in the garage, or put it in a different room. The little sub will hold the big one back, and the phase relationships will be different and will likely just be a mess.
