herosgym
HI,
i recently posted a question on here about a audio setup for my gym, i had found certain things i needed on ebay but missed out on most of them.
so what i have is 6 speaker wires put in downstairs and 4 upstairs, so a total of 10 speaker locations.
so i am in the uk and want to spend about £1500 max, please can you post me a setup for under this?
all i am trying to do is be able to change the volume upstairs, maybe a volume control up there or something at the reception and maybe be able to change the volume of the 6 speakers down stairs, these could be chaged in pairs though if easyier.
so as i am a complete begginner to audio i would just love a shopping list, you need this, this and this and a few tips on what to do and i will be so geatfull.
all the speaker wires for all 10 locations go back to the reception, and as i might have a young lady or man on reception it would be nice if changing the volume in areas was simple.
hopefully someone can help and i can get everything ordered. secondhand things could even be an option if you think they do the job.
thanks loads
ben
BMXTRIX
BMXTRIX
Ben - While we've been through all of this before, I think you really need to find out what in the UK is available to you as local purchasing resources. I have no idea what you have locally which you have access to for stores and for potentially getting quality used gear from.
eBay in the US is a goldmine of used A/V gear, and we also have Audiogon for higher end gear.
At the very least I would get two amplifiers, impedence matching volume controls, and speakers for the different areas.
But, without a local store where we can get some pricing from, it's very difficult to see what options you really have.
