Setup Denon AVr 3808CI and Channnel Plus MDS 6A
pezram
I am pretty much a rookie at this and originally the system was not set up by me. I am wondering if anyone can tell me how to hook up my Apple TV so I can hear it over my Channel Plus system. I hooked up my Apple TV using an HDMI cable to the Denon through the DVR HDMI port. I used RCA cables to hook up from the DVR out on the Denon to the open Channel plus channel. The apple TV works fine on the TV but no sound through the Channel plus. Any suggestions would be appreciated. My apologizes, if I have posted this in the wrong place.
adk highlander
adk highlander
Sith Lord
What version of AppleTV do you have? If it is the older one with Analog (RCA) connections you will need to connect those to the receiver. The RCA outs on the Denon (either preamp or Zone 2/3) will only output analog connections and will not convert an HDMI input.
pezram
Thanks for reply . Its a generation 3 software version 5.1.1(5433).
pezram
Thank you for the info when you say PCM I will be still able to watch video through the hdmi connection correct.
adk highlander
adk highlander
Sith Lord
PCM is the audio and should not effect the video. It will mean the appletv will have to downmix anything that is dolby digital to 2 channel PCM. I am not an Apple person so I would check the manual to make sure it will do this. I am fairly certain it will but I am not 100% sure.
