I've got some questions for setting up my subwoofer wiring for the two 5.1 setups I have.
With my old Energy XL-S12 subwoofer, i always used an RCA subwoofer cable and plugged one side of the RCA cable to the Subwoofer input plug and the other side to my receiver. I did not plug anything into the Xover input plug on the Subwoofer. I also have the option to to use the High level L/R input/output with regular speaker cables, but have never used those connections. Is there any advantage of using those?
With the energy my controls are the following with the settings I have it on:
-Bass EQ (-3 to +3) - set to 0
-Phase (0 to 180) - set to 90
-LP Filter (50 to 100) - set to 90
-Bass Volume (0 to 10) - set to 5
With my new KEF Q400 subwoofer, there is only a Left and right RCA input and the only control is volume. Right now, I just arbitrarily choose the right side plug on the subwoofer and plugged the other side on the receiver. Is this correct, or should I purchase a Mono to Stereo RCA Y cable, and plug the side of the cable that has 2 sides into the left and right plugs on the subwoofer and the end of the mono end of the cable into my receiver?
Would appreciate advice on how i should setup both subs and some recommended settings for my Energy subwoofer.
